5.7 GSI PEFS horspower
Alaskapete
Hello everyone,
I purchased a used 5.7 GSI PEFS motor and am wondering what the horsepower is on this motor. Also is there a way to figure out the year based on the serial number?
Thank you
Fun Times
The HP looks to be in the 280 range... http://forums.iboats.com/forum/engi...orsepower-rating-for-a-2000-5-7-gsi-dual-prop
The info below is what comes up doing an online search of your serial number
[h=2]View Individual Product[/h] +
Individual Products in Unit
Individual Information Serial Number 4012023312
DriveLine VPH1 139115
Status Commissioned
Manufacturing Date 5/31/2000
Shipped Date
Delivery Date 6/28/2000
Detailed Segment - as sold Marine Leisure Diesel
Control System
Control System Version
Rated Power
Rated Speed
Property Value
Technical Data
Name Value
Product NameG6-A-AQ-23
Product Designation5.7GSiPEFS
Part Number3869059
Production Period1999-2002
Number Of Cylinders8
Bore101.60 mm
Stroke88.40 mm
Compression Ratio9.4:1
Displacement5.73 liters
Drag a column header and drop it here to group by that column
Operators manualInstallation and Operation, Battery Management System 2.2 MBEnglish true
Operators manualOwner's manual Model 'EF' 1.7 MBEnglish true
Workshop manualSupplement, wiring diagrams Wiring diagram suppliment to 7743244 which replaces 7797355 'EF' Electrical, Fuel, and Ignition workshop manual.
(Only available in printed version)
858.8 kBEnglish false
Workshop manualWorkshop manual. Electrical, Ignition, Fuel Replaces 7797355 with wiring diagrams moved to supplement publication 7743245
31.8 MBEnglish false
Workshop manualWorkshop manual. EFI Diagnostic 'EF' models
21.1 MBEnglish false
Workshop manualWorkshop manual. Engine Components 'EF' models
77.9 MBEnglish false
Service ProtocolService Protocol, new products in storage 126.0 kBEnglish
From the owners manual...
5.7 GS/GSi
Battery size 12 volt with 650 Cold Cranking Amp (CCA) rating Bore and stroke 4.000 x 3.480 inches (101.60 x 88.39 mm) Carburetor (GS) Adjustable idle circuit Fixed main fuel jets Electric choke Charging system 65 amp alternator, with internal transistorized voltage regulator Cooling system Variable volume pump on engine Recirculating pump on engine Thermostatically controlled temperature Cylinders (number) 90? V-8 Displacement 350 cubic inches (5.7 liters) Firing order 1 ? 8 ? 4 ? 3 ? 6 ? 5 ? 7 ? 2 Fuel filter Volvo Penta P/N 3852413 Fuel filter location Refer to photographs on pages 24 through 27. Fuel type Inside the U.S.: 89 octane (AKI) unleaded gasoline Outside the U.S.: 93 octane (RON) unleaded gasoline Full throttle operating range GS: 4400 ? 4800 RPM GSi: 4600 ? 5000 RPM Idle RPM (fixed GS: 550 ? 650 RPM in forward gear GSi: 600 RPM Ignition timing Authorized Volvo Penta dealer service only Oil capacity Engine Without filter: 5 quarts (4.7 liters) With filter: 6 quarts (5.7 liters) Drive unit SX: approximately 2.2 quarts (2.1 liters) DP: approximately 2.5 quarts (2.4 liters) Oil filter Volvo Penta P/N 3850559 Oil filter location Refer to photographs on pages 24 through 27. Oil type Engine DuraPlus? Premium engine oil labeled for API service CE/SG Drive unit DuraPlus GL 5 synthetic gear lube Power steering fluid DuraPlus power steering fluid Spark plugs Volvo Penta P/N 3854399 Spark plug gap GS ? 0.035 inches (0.89 mm) GSi ? 0.045 inches (1.14 mm) Spark plug installation torque 20 ft. lb. (27 N?m)
