Volvo Penta Engine Model 572 (5.7L GM). Approx year: 1993
Ran fine fall of 2011. Sat up since then. Now cannot be turned by hand.
Using info learned here, I have pulled plugs, lubricated cylinders, waited a couple days.
No water noted when pulling plugs. Plugs look fine overall, no rust, a little dark as if running rich.
Squirted 2 oz of Marvel mystery oil in each cylinder using a cajun injector syringe.
Attempted to turn via alternator nut with tight belts. No help. Pulled sea water pump from crank pulley. Attempted breaker bar on 5/8 bolt in crank, but am leery of stressing the bolt too much. Bolt turned a little but not engine.
Decided to try starter, which just spun. Pulled starter and bendix is frozen and won't extend.
Teeth on ring gear and starter seem fine.
Cannot get any leverage against flywheel to try and turn engine with it.
Ideas to try possibly:
Should I pull lower unit, just to ensure it's not something besides pistons? Is there anything else that might be causing this.
Using the three bolt holes in the crank pulley where the sea water pump was mounted, get longer bolts that extend out enough to allow a pry bar against them.
Impact driver on crank bolt hoping that vibrations will help loosen pistons. Unsure if air impact will ultimately break the bolt.
Spin the oil pump with an oil pump primer tool to circulate oil through valve system, etc. Probably add an additive to oil first.
Buy a new starter and run it against the engine. Not sure what happens to a starter when it meets an immovable force. Don't want to break things, especially on a brand new starter, nor the ring gear.
Also, yesterday I decided maybe there wasn't enough lubricant in the cylinders so I added a 50/50 mixture of ATF and acetone, based on some advice I'd read and filled them to the brim. I noted that the port bank of 4 cylinders took a little over 3/4 quart. The starboard bank took much less, may a little less that 1/4 qt for all 4. Does that make sense? I'm not that smart on internals.
Thoughts? Thanks!
Thoughts? Thanks!
