1979 Quartermasters
- May 30, 2009
- 505
Good day people:
Finally got around to dismantling a 1998 5.7 GMC Vortec engine I acquired last summer. I swapped it out for another for a friend of mine and he let me keep the old one. I thought it might be a head gasket, but they didn't show any obvious damage. So I'm thinking its a cracked head as he over heated it a couple of times. It had a nice thick milk shake in it and when i took it apart, #8 had some coolant in it. The pistons came out easy (little or no ridge), and everything seemed to be in pretty good shape. All the passages were full of the redish sludge. There is some rust in the top of cylinder #8.
The current engine is a 1995 5.7 bored .030 over and other wise stock with about 550 hrs on it. I do have Corsa switchable exhaust.
So here is my plan.
Block cleaned and checked for damage. If it is good, I was thinking bore it .030 over and get it decked.
The crank looked good, but I'll get it checked and repaired as needed.
I would like 300 to 350 hp and convert it to a carburetor.
I am aware of the reversion problem, but would like as lumpy of a cam as possible (cool factor)
I can turn a wrench, but have never built an engine from scratch.
I don't understand all the lingo of lift, duration and all that stuff, so I was hoping some of you guys would advise me in that department.
I see the fuel pump mount is there, but there is no hole to the cam. Can this be machined or do I have to use an external fuel pump?
Is this a feasible start, or am I out to lunch on this.
All input welcome........
Thanks, Ken
So here is my plan.
Thanks, Ken
