A faulty neutral safety switch wont make the engine "run bad", it will make it not run at all. It grounds out the coil so you don't get spark.
Ayuh,...... Welcome Aboard Paulie,..... Lotsa points to cover in this thread,.....
Plain, 'n simple, you've got a carb problem,..... Best advice is to do as Scott stated in post #7,.....
It'll fix yer carb, 'n determined whether you've got problems up-stream in yer fuel
System,....
Step #1 is to pull the fuel filter, 'n examine it's
Contents for anything but clean fresh gasoline,.....
A plan of action can be developed from there,....
Lastly, this ^^ quote is all wrong,..... MP is explainin' the operation of the
Shift Switch,.........
Not the neutral safety switch,....
The neutral safety switch only breaks the voltage from the key, to the starter,.....
It has absolutely no bearin' on how the motor
Runs,......
It only disables the Starter's
Start circuit,.....
Not complainin', just pointin' out the typo for future reference,.....
As Mad Props obviously knows 'bout what he speaks,....
