5.7 4v ignition module thunderbolt IV question
kennycarter
Have a 95 4v 5.7 mercruiser 4V in a 95 SeaRay. The distributor has the ignition module & one other sensor on it which I assume is a knock sensor. I have been told this is a thunderbolt IV, but read here it is a thunderbolt V?
The boat will spin but not start, it will spark only one time & the spark is short & red. We have replaced the coil.
We did the test on the flow chart (though perhaps not correctly) and believe the module is bad. Before it quit running altogether, it had shut down in the past, but after a bit always started back up.
We have been told the module # is replaced with 807264A01 ($570 from the dealer), but this will require cutting & splicing the wiring harness, as it does not plug in like the original.
So any way to be certain of the correct module, as we have been given 3 numbers already & restocking fees are expensive?
Or can we just replace the distributor & module with a complete aftermarket marine performance distributor, like petronics?
Thanks
Don S
Re: 5.7 4v ignition module thunderbolt IV question
Thanks
What is the serial number of your engine.
A Lot of "I have been told" comments, time to find out what your really have.
kennycarter
S/N engine OF586258 1995 350 magnum, alpha one, with 4v carb
Don S
Is your ignition module mounted on the distributor or the exhaust elbow?
kennycarter
ignition module is mounted on a bracket on the distributor along with a second electrical part.
kennycarter
Thanks so much for the help & the catalog link.
I believe I started with that part number in the beginning & the rep checked:
The part a mercruiser dealership sent was 805361T3, ordered using our serial number, & it had the wrong numbers of pins & did not plug in. Ours has 8 pins. I read the catalog as being 805361T6 I believe.
Are these 2 different parts ? (sorry to be dense, but I can't believe its so hard to get the right part)
Since then the first parts store gave us a second part number, then the mercruiser tech line has given us another number, #806957T2, which was replaced by the number I had, according to 2 web searches I did.
Thats the reason I asked about using an aftermarket system, I am no longer confident of getting the right part and hoped I could find the right part here. or how to go to some other system, the restocking fees will get outrageous if nobody can agree on the right part number.
kennycarter
32 806957T 2 MODULE, Ignition (350 MAGNUM ALPHA) SN# 0F353691 & Up
23 805361T 6 IGNITION MODULE (260 - 5.7L ALPHA) SN# 0F273498 & Up
I can now see how I got 3 different part numbers from 3 different reps.
I think it is 805361T6.
The cover over air cleaner says:
Magnum 350 Alpha One
S/N engine OF586258
but I am concerned that the merc rep gave us the other number and that one is a $570 part!
any way to be sure which one it is???
NHGuy
see Don
Don S
Here we go again, trouble shooting without being able to see anything.
Your engine should have a Thunderbolt IV ignition system by the serial number you gave.
Problem is, I just added these two things together.
Ours has 8 pins.
Put those two items together, and you have a Thunderbolt V ignition that didn't exist in 95 and only has 5 pins, not 8.
Something is wrong, and I don't have a clue what it is or why.
Did you get the serial number off the engine, or off of some old paperwork.
kennycarter
Serial number is off the cover from over the carburetor, we are 2nd owner since 2001, & it was serviced by the dealer from day one, low hours when we got it. we have all the paperwork on it since new, I see a ticket for a warranty recall on the control box , but nothing else.
is there some other place stamped on the motor I should look at for the model number?
Don S
A digital camera does wonders if you can't see it.
attachment.php
kennycarter
Model number on motor is the same F586258, except I can't see the O at the beginning.
The original coil says thunderbolt IV, we tried the original & replacement coil on an old Mustang just to verify our findings that the coil was not the problem & it will run the car.
Based on the flow chart we have a bad module, we have run the tests 2 times & get the same readings.
Our module has a nippon denso number clearly marked, but the mercuriser sticker has faded till no numbers are visible.
Any way to figure out which one to order? Or any way to put an aftermarket system in here?
Don S
Error on my part, :redface: :redface: I was reading serial number wrong.
You are supposed to have TB5 and you are supposed to have this module.
806957T 2 MODULE, Ignition (350 MAGNUM ALPHA) SN# 0F353691 & Up. Everytime I looked at that serial number range I would somehow decide your number was 0F286258 instead of 586. :facepalm:
kennycarter
Do you know of any way to get a correct module, that is a direct plug in, instead of the replacement which requires splicing the wires?
Don S
Nope, but the OEM kits of anything usually come with all the parts needed to change things over, including splices. They typically include instructions too.
kennycarter
Thank you so much for all of your help. After paying to restock parts that dealers sent that were not right, & getting so many different numbers I was ready to replace it with aftermarket. Part is still very expensive, but I will give it one more try.
Will follow up & let you know if its the right part this time!
BTW thanks for all your postings of the flow chart to check the ignition system, they were a great help.
Don S
If it was my boat, the TB ignition would be gone. 570 bucks for a module is stupid. You can buy a complete Delco EST marine system for a lot less than that module alone costs.
The TB ignition is a fine ignition system, but lately the cost of repairs has gone through the roof. Those modules were only $150 a few years ago.
Example http://www.michiganmotorz.com/delco-voyager-marine-electronic-distributor-p-119.html
They worked great in cars and trucks, and Volvo still uses them on carbed engines.
kennycarter
Do I need to worry about the shift interrupt that I thought I read was on TB ignition system, or will this aftermarket kit take care of it? Since I have to splice anyway, I would rather go the most affordable way. Thanks again
Don S
The EST will work with the shift interrupt fine, the 3.0L has been using it since 1990. It does work different, but not much to change. Plus there is plenty of help here if you choose to go that way.
