Had the boat out today for its maiden voyage after my rebuild, overheated right away! so brought her back home and worked through the cooling system, decided to replace the thermostat and the lower water pump impeller. Now I have it all back together and its cooling fine, my question is, should I have equal amounts of water coming pout of the water exit outlets on the outdrive or is it normal for one side to have more than the other. Temp seems to be running right around 140-160 degrees on the muffs.
