skydiveD30571
- Feb 13, 2012
- 1,042
VP 5.0gl-h with stock 2bbl Holley carb. list # 75034, date stamp # 2276
I learned the hard way yesterday what the difference is between setting idle mixture on the driveway vs. in the water . It sure sounded good on the hose, drop it in the water last night and trouble right off the bat.
I'm still battling an idle/start problem on this engine. Trying to set the idle mixture correctly to help with warm starting. It idles nice and steady, but warm starts (5 minutes or more) are trouble. It's not a hard start, it turns over really quickly actually. But it doesn't seem like it catches too well. For example, if I shut it off, wait a few seconds, then start it again, it has a nice strong start where rpm's rev up then drop down to a solid idle speed (just like a modern car). After waiting a few minutes then trying, it kind of stutter starts like it barely catches. Then rpm's come up but not very high and the idle lopes up and down (about 700rpm - 400rpm) until I give it a little throttle and return to idle. Then it's nice and smooth.
I called Holley, and they have absolutely no information on the carb since it's a "proprietary Volvo model" :facepalm: I looked in the service manual, but according to the volvo penta website, it says to use the 5.0gl-a/b/c/d/e manual for the -H engine. There are no carb specs for the -h engine, and I know they're different than the rest since my stock power valve is a 10.5...higher than the latest listed engine the gl-d/e. I'm guessing Volvo hasn't updated any manuals to inlclude the -h version, but I'd appreciate it if Don or anyone else familiar with manuals could comment. Also my float level is less than parallel while inverted, but I have no hesitation or any other problems outside of a loping idle after a warm start. So I'm not sure if that's right either. Any ideas guys? I'm at a loss here.
