Hello all and its nice to be back here!
Preparations for the summer stumbled upon an unexpected problem: after a few months of not having operated the engine and having disconnected the batteries I put everything back in normal order and tried to start the engine. I turned the key in position 1 and nothing happened: no beeps, no sound from the fuel pump, no response from the gauges. I turned the key to the start position and the starter worked perfectly but the engine never started because nothing else propably worked. I checked the engine switch( on the helm with the key) and it perfectly receives 12v and sends it in both key positions. I also checked the three big fuses on the engine and the 50amp circuit breaker and they also seem fine. The only things I havent checked are the starter relay( located at the same spot as the fuses) the ecu and the ignition module because I dont know how to. Ignition coil, spark plugs and wires as well as the distributor cap have been replaced a few months ago and everything worked a treat at the time. Can anyone please help me on this? Any ideas of what could be wrong?
Thank you very much in advance!!!
