I have a 93 23' Chaparral cuddy. I bought it 2 years ago so I don't know much about the maintenance history.
The trim issue... It trims up just fine but will not trim down at all. Currently it is all the way up. Since I've owned the boat I've had intermittent trim issues but usually 'fixed itself' after short periods of time and / or cruising around.
The pump sounds fine, fluid is pretty low but there is still fluid in the reservoir. I've never checked the fluid before so I'm not sure if it has dropped or not since I've owned it but I'm going to assume it has over time. I was told intermittent trim issues is usually related to the cylinders themselves, but I'd rather not spend money that I do not have to. What would be a good way to troubleshoot this, or should I just go ahead and replace both cylinders? I've also read it could possibly be a check valve in the line or pump or potentially the limit switch on the outdrive. I don't believe it is related to the limit switch. I'll note the steel braided lines going to the cylinders look pretty bad, the steel is starting to shred but I don't believe the inner hose(s) are damaged.
The engine fired up first try this year, we put it in the water and was ready to take it to my slip but it would cut out immediately when put into gear, both ways. I've been told and I am pretty confident this is related to the lower shift cable. I tinkered with the adjustment a little bit, the best result I had gotten was being able to put it into forward normally but with that setting it would grind horribly in reverse, the prop would still spin but it definitely wasn't right. I tried a few different settings and got grinding in both directions until I got to the point where it would go into forward and grind in reverse then I gave up. Hoping I didn't make things worse with the grinding. Shifting does feel pretty tight as well, but I'm not sure if it's any tighter than it has always been.
Also when I first put it into the water and was attempting to move it to my slip, when it was cutting out. The last time it cut out the engine wouldn't start at all, it didn't even seem like it was trying to fire at all after many attempts. I'm going to take a guess that the issue was related to the cut out switch on the shift assembly. I tinkered around the switch and got it running again a few days later.
In conclusion... I believe I'm definitely going to install a new shift cable, while I am there I'm guessing it would only make sense to put in a new gimble bearing and bellows. Should I just go ahead and replace the trim cylinders and lines while I'm at it? I ask because I'm not sure if these are a regular maintenance item or not. If they don't typically go bad I'd rather not waste money replacing them and would prefer to troubleshoot which, if either, has gone bad.
