jonthearcher
- Jun 3, 2013
- 8
Any help would be appreciated. I just bought a 2002 larson 210 lxi with a volvo penta 5.0 gxi raw water cooled engine. The boat starts and runs great. The only issue I have found is that the hot water outlet near the top of the motor is shooting a hot water stream into the bottom of the engine compartment. I'm guessing this water should be redirected to the outside of the boat. If I run the bilge pump the water is evacuated fine. Should there be a plug on this or a tube to the exterior of the boat? The boat runs at normal or below normal temperature. Thanks in advance for the help.
