Hi I am working on a 2000 mercruiser with a tbi 5.0, the engine is laboring when we try to bring it up to full throttle. We have replaced everything on the ignition system except the plug wires. Also everything on the fuel system has been replaced except for the fuel pump, and the fuel pump is putting out 70psi at the back of the throttle body with mechanical gauge. Talked to mercury techs and they said that the fuel cooler may have been frozen and causing a restriction, replaced the cooler to no avail. We are at wits end any help would be greatly appreciated thanks in advance.
