2002 MCM 5.0L Alpha MPI 0M616xxx ECM 555
Hello Everyone. I am trying to figure out what is causing the below symptoms. It is like someone is turning on and off the key or the kill switch very quickly. However, the gauges and accessories stay on.
Cruising along between 800 and 2000 rpms
The majority of the time the issue appears to happen when we are slowing down and dropping below 2000 rpms or in idle as we are trying to dock the boat.
The issue will not happen over 2000 rpm. In fact, when the boat was beeping multiple times, I speed up to 2500 – 3500 rpms. Boat runs great. I did this test multiple times, As soon as I get below 2000, the issue can start again.
Oil pressure and temperature are in normal range.
History:
Can the ignition switch be ruled out since the gauges all stay on at the time of the beeps?
The wiring diagram from the manual shows a purple wire from the ignition switch wired to the kill switch then wired to the tach. However, when I toggle the Kill switch, the motor is killed but the gauges remain on. How is the Killswitch wired? The diagram shows the kill switch wired in series to the tach.
If the main relay is intermittingly going bad and dropping out, would it cause the alarm to sound? I plan to switch the main relay with the fuel relay and see if the issue continues.
If the interrupter switch is the culprit, could the alarm sound if the switch is dropping the RPMs?
Is there anything else I can check?
Thank you for help in advance.
- Quick Audible alarm/beep would sound and the RPMs would drop 500- 1000 rpms.
- The motor catches back up
- It could alarm/beep 1 time an hour or 3 times in 5 secs. (alarm does not stay constant or beep 2 times a minute)
- This would happen in gear and neutral
- All gauges and accessories stay on.
- Could happen within the first 5 minutes or hours of running.
- Quick audible alarm/beep and the RPMs drop and the boat would stall
- Then I hear the fuel pump would start just like when you would turn the boat on for the first time.
- Intermittent - May not happen for hours or 5 mins of starting the boat.
- The engine will start right back up and may run for a little while before it happens again.
History:
- Purchased the boat last year. Ran great for the one week we were able to use it.
- The issue started the first day of this season
- Local dealer scanned the ECM. No codes were found.
- Checked every connection that I could wiggle/ move to try to make it happen again. Including the ignition and kill switch.
- Took apart and cleaned and expanded the pins on the 10 pin harness. Used Dielectric grease and snugged back together, In fact, I did this twice because it seemed like the issue went away for a day. No luck the second time.
- Removed grey wire from the tach. Still happens
