5.0 Mercruiser EFI Layup
riverboaterbill
Hi Guys,<br /> Is it OK to fog a fuel injected engine by squirting fogging oil down the air intake? A friend says it may clog the injectors. A shop manual reference says to remove fuel filter and fill with a mixture of outboard oil and gas, but mercruiser tech says he uses can of fogging oil???<br />If the fuel filter must be removed, filled, and the engine run out of gas, there is no fuel shutoff. How do you plug the fuel line? Does anyone know how much pressure is in the fuel line. Thanks a Lot! Bill
