Hello iboats members
I count this site among my most valued resources The wealth of info in the archives, stickys, etc is incredible. I have tried to avoid this post by searching the archives for info, but am unable to find a couple of answers I think can be quickly dealt with by an experienced VP person.
I have a 2001 20 ft Glastron with a 5.0 L GL / SX. (Motor is also a 2001). Bought last August, dealer maintained, pristine condition, used a few times, worked flawlessly. Winterized according to the manual, changed oils, impeller, and took it out for an hour run 2 weeks ago. had a couple of minor issues: A faint squeal I thought may be a belt. Belts are tight, noise seemed to fade away. Trim pump was a bit noisy, reservoir was low, topped it up to line.
Here's where the trouble starts: Went out Friday eve, warmed it up on the trailer, engine overheated and alarm came on as soon as we started to pull away. Shut down, cooled off, idled 100 ft back to the trailer with the alarm screaming, but kept the temp in the just above normal range. I had noticed a lot more mud / sand stirred up around the prop coming off the trailer than usual. I think the bottom has changed with the spring freshet in the river where I launch. (not a boat ramp). Checked for blockage at the intake screens, no muck there.
Tried it again on the trailer, still overheating. Pulled the impeller, looked fine, no sand as expected. tried a new one anyway. no difference. Sucked on the inlet hose from the raw water pump, pulled up water while on the trailer in the river. Pulled out of the water...ran water into the flush hose fitting with the engine turned off. and discovered water coming out around the plastic pipes where they go into the brass impeller housing. As I've read here, a new housing is needed. I'll order one today, but just to rule out other problems, I shoved a very tight 3" piece of heater or rad hose over each bad joint and clamped them off, 4 clamps. Water leak stopped completely.
Primed the raw water pump from the top of the hose on the thermostat housing, just to help it get rolling, then back in the river on the trailer. After what seemed like a long time idling, but may have only been 5 min, it overheated again.
Finally, my questions:
Would a bad thermostat cause an overheat?
Could the water circulating pump be shot?
Is the sucked up mud and the bad raw water pump fittings possibly just a coincidence?
What to do now? If take it to a dealer, i won't see it again this summer, and will spend a small fortune, I'm sure.
Thanks in advance for some advice guys!
