Engine is a 5.0GXi-G, FI, 2007 model
My temp gage isn't working, but when I short it at the gage, the needle flips full scale. That to me means it's the sending unit or wiring to sending unit.
I bought a new sending unit with a one wire connection, however for the life of me I cannot locate that thing on my block. Here's what I found: A. ECM sensor(switch) on t'stat housing,2 wire conn, B. MAP/MAT sensor, 4 wire connector near rear of manifold, . C. A knock sensor on each side of block down low about in center. I've found the high temp sensors on the exh elbows, but these are safety's. I think it's a tan, one wire connection tothe sending unit.
I've also looked on http://www.volvopentastore.com/Inta...*****.627209542--store_id.366--view_id.320771, but cannot locate sensor.
A diagram would be GREAT!
The boat is about 150 mi away, but I'm going up soon to look again.
