5.0 ford efi. Pulses at 3000 rpm
Hotrodnut
Got the motor to run after sitting for a couple years, idles fine with a little pop on the port exhaust side... When I try to throttle up to plane it pulses at 3000 rpm and won't go faster
jerryjerry05
Re: 5.0 ford efi. Pulses at 3000 rpm
Possible, the vent line is clogged.
Check for water in the gas.
Do a compression test.
Plugs burning OK?
