Everything was running fine for about an hour. After picking a skiier up, and turning on the engine, it started revving irregularly - high and low in neutral (from 600-1100rpm). When in gear same thing, with little power, almost stalling, and a strange clicking noise...sounded real bad! Gets wierder...when I moved the outdrive up or down, engine was powered, and seemed to run fine. I cycled the outdrive up and down to get to shore and then waited for a tow. I am totally baffled. Electrical problem? EFI problem? Your insights as always much appreciated.<br />Signed totally bummed Searay owner
