hydroscott
Thread starter- Joined
- Jun 1, 2003
- 2
Hi All, <br /><br />I have a 1970 4hp Johnson. Had a problem this spring, wouldn't run at high speed unless the choke was pulled about 1/2 way on. I replaced the fuel pump and replaced the needle, seat and float in the carb. Now it runs great at idle but when I pull the throttle past about 1/4, it runs rough and very rich. Plugs are soaking wet and tons of smoke. I have done the following: Swapped all carb parts back to original, swapped fuel pump back to original, checked spark with timing light, checked advance with respect to throttle opening per manual, checked fuel pressure, set float level, changed gas, changed plugs, set high and low speed needle valves per manual. None of this had any effect. I read a previous post about a "bad or missing main nozzle gasket" but I don't know what that is. Adjusting the high speed needle valve all the way in until it bottoms out has no effect - still runs way rich. Any ideas? I'm about to send this thing to the bottom of the river. Thanks.
