hey guys, let me run this by some of you guys. 48 evinrude m#e48esleim, s#g02980685. problem, runs great at idle but when you rev it past half throttle it starts surging. figured carbs clogged at high speed circuit. removed carbs cleaned (soaked in carb cleaner overnight). re-assambled and installed. the carbs were not that bad. dumped old fuel for new, changed the plugs (NGK equivilent) ran motor but still surges. here is the bizzare part, I have heard of this happening but not to me. the eng started reving out like there was no rev limiter. turned the key off, still kept reving, pulled the tether, still reving, pulled the spark plug caps off of the plugs, still reving out. I unhooked the fuel line and it stop after a min. or so. all the time it was hooked up on a flush. hooked everythig back up and it ran fine at low and high speed for about 10 mins then it started suging again at half to full throttle, now I am thinking that it may be an electrical issue, did a search to see if anyone has had this issue before but found nothing. any help would be greatly appreciated
