48 spl johnson
DOGHUNTER
top carb. spitting out fuel from high speed needle jet (is a fixed jet) I soaked the carb in cleaner for 8 hrs. and still does it
almost retired again
Re: 48 spl johnson
Hi Doghunter,<br />You might check the reed valves behind that carb. It might not be seating properly.<br />Just a thought
hondon
Re: 48 spl johnson
What kind of carb cleaner did you treat this with? If you soaked it in carb dip you have just done more harm than good.
DOGHUNTER
Re: 48 spl johnson
I used a napa brand carb. cleaner & I have used it many times on carbs previously and has done well thanks also whenever I run the engine it will bog down at full throttle and at times it will catch and run like a spotted ape
