48 Johnson fuel pump/3 port/ lines
ba_50
This '96 motor's fuel pump won't let the fuel go through while pumping the bulb. Doesn't the manifold line go to the outside edge and the fuel to carb line go to the inside port?
Thank you.
tashasdaddy
Re: 48 Johnson fuel pump/3 port/ lines
do not understand your question. did you check filter. the manifold is after the fuel pump. it splits fuel from pump, to both carbs, and to the primer solenoid.
ba_50
TD
Sorry. I need to know where the two lines on the edge of the fuel pump go to for sure.
