470 - Oil Pump Alignment ?
Rake722
Hi All, Im rebuilding my 470 and dont have this alignment tool.
Is there any other way to install the pump and ensure alignment ?
Thanks
Bt Doctur
install the dist first, then install and tighten the oil pump bolt
Rake722
I left the oil pump installed on loose bolts, then inserted the dist, then torqued the oil pump fasteners. That way the oil pump was free to move as the dist was inserted.
