I have a 45hp Chrysler Outboard that I cant seem to more then 5 mph with out on the water. It will start and run smooth, and idle, but as soon as i try to open it up out on the water nothing. The boat wont turn any rpm while trying to move. In nuetral I can get it the rpm up. Its getting fuel to the bowl in the back of the motor, it is full as well as the bowl under the carb.
I thought maybe I had a bad plug, pulled the top plug out and could see that it was getting spark, however when doing that the motor started and ran just as smooth as it did with it in. Could not do it with the bottom plug out. Replaced them both and tried again. Same result. I have no idea where to start with this thing. Im not to familiar with outboards and have no mechanic in the area to bring it to.
I could probably figuire it out with some guidance and repair it myself.
Any direction would be appreciated.
Chad
Chad
