- May 16, 2009
- 9,291
You in my opinion probably have an internal VST tank issue (Vapor Separator Tank) as what you described was sort of a common issue with these models and if not then you'd probably have a MAP sensor issues or a fuel regulator problem as those are "some of" the biggest fuel flow contributors for your fuel system for an over rich condition as you described... Which if you do have a VST issue, the scan tool won't necessarily tell you pinpoint-ally the issue but more by way of you really knowing what the normal injector flow rates usually flows at in the live data for your engine model under normal conditions plus a few other data readings too in certain combinations....< And bear in mind that the same condition could accrue with the MAP sensor depending on the range of the MAP senor is putting out to the ECM vs actual problem.Wow now we are talking good info!!! Its a 1996 454 MAG MPI serial 0F764338.
standing behind the boat smells like raw fuel, it uses a gallon of gas within 20 minutes or less just at idle. What can cause this. Fuel pressure is at like 30 psi and no fuel leaking anywhere.
The low fuel psi may be because the excess fuel is escaping out the engine/VST too fast to show the correct psi at the fuel rail.
The most probable causes would be the diaphragm is bad inside the VST, debris inside the VST causing fuel float type issues inside the VST such as fuel soaked float, sticky float valve kit which is basically the needle and seat kit like found in carburetors getting stuck or possibly the fuel regulator is bad...Again sensor wise ought to be the MAP being that much fuel going through the system.
Check the clear or yellow tygon type tubing on top of the VST fuel vent system for fuel inside the tubing...There shouldn't be any fuel inside... Item number 26,http://www.mercruiserparts.com/bam/s...31796/1614/150
Also check the two rear engine cylinders # 8 first and # 7 if needed for excessive raw gas as again those are signs of a failed diaphragm or needle and seat in the VST.
http://ww2.iboats.com/502-EFI-GEN-V-...iew_id.1693335 ... https://www.perfprotech.com/mercury-...g/umodel/10489
