45 HP Mercury Stuck in Forward Gear
jknowles
I have a 1986 Mercury 45 HP Serial #A949831. On way to lake last weekend was hit from behind by a car. Motor is on a transom saver so most of the impact was on the prop. Hard enough impact to feel through trailer but no visual damage. Motor will start and run normally but stuck in forward gear. No neutral or reverse gears. Have removed lower unit and shift cables operate freely. Please reply with what I should try next. Thanks
petryshyn
Re: 45 HP Mercury Stuck in Forward Gear
gonna have to disassemble lower unit. Prop shaft may have been driven deep into the forward gear.
jknowles
Thanks for the help schematic, you were right. Went back together as the manual called for. Going to run it a little and check it again to make sure.<br /><br />Thanks
