Re: 45 hp honda impeller replacement
thanks, but I found it! there is a stainless rod that is part of the shift linkage located about half way up the lower unit on the transom side that has a jam nut and a threaded collar. just loosen the jam nut and unscrew the collar and it seperates the top half from the botton half.
