lazzlonewolf
- May 26, 2010
- 21
i have a 40hp merc outboard. it wont run under a load runs fine in a barrel put it in gear tries to keep running. idles fine. iv replaced everything the stator all the fuel lines compression test 120PSI in each cyc.all new wires. fuel pump. plugs.new gas ,seafoam.I finally took it to the pros. they charged me $75 to say i had the wrong carb on it. i put the orginal on it an it ran like **** then it wouldnd even start. put the other carb on ran good again. but not under a load.the carbs are different one has a hose running out to the carb, i plugged it with a toothpick cause the float bowl i have dosnt have a connection for it. anyway i need to know where i can get a carb with #1368-5036 on it?? also i cant find the year of the motor s/n#3585874? the carb has WMK 8-1-1 on it? its a 38-1 38-2 38-3 i found one on e-bay with 8-1-0 on it will this work? or find a float bowl cover with that hose connector. help i want to go fishing before it gets cold..... Shawn in Michigan...
