heapsofjeff
- May 12, 2017
- 5
I just bought a boat and it will only go 8mph. I have read others with similar size boats and engines get 24-30 mph. I cant seem to figure out what is wrong? It is a 1971 arrow glass fiber glass 15' boat. It has a 1971 Johnson 40 hp engine (40EL71B model) with a 10.5x12 prop. The engine seems to run good and smooth. I tried pulling the plug wire off 1 cylinder and it was obvious rough and slower. Tried the other and same, so seems both cylinders are working. I replaced the plugs with j4c plugs after reading the j12c that was in it was wrong, but no change. The boat does not have a tach so I am unsure if there is cheap way to rig one up to diagnose. Thanks for any things to try.
