hey guys,
I bought a very low hour Bass Tracker Tournament TX17 with a 1992 Evinrude 40hp outboard. The motor will start up and begin to idle like normal, it will run for about 30sec and then just shut off. It struggles to restart unless I press in the key to choke it, it will restart up. The motor revs up nice an smoothly once in gear. One thing i noticed is that when idling if i press in the chock every few seconds it will idle forever, as soon as I stop randomly pressing in the choke it will eventually die. I have disassembled both carbs and throughly cleaned them, i pull out both jets and made sure they were clear. The carbs were not dirty at all to begin with, the floats move freely and seem to be adjusted correctly from what i have researched online. The spark plugs are new. The fuel filter is newish and not clogged in anyway. The primer bulb and the fuel line running to it were replaced by the previous owner. Please watch the video below so you can see what i mean by it eventually "shuts off". I know this is usually fuel related, but just need a little advice of what to check next. Thanks!
http://vid33.photobucket.com/albums/d75/atvkid4eva/IMG_4701_zpsbii8iy86.mp4
