40 johnson VRO
JRJ
Re: 40 johnson VRO
Variable Ratio Oiling is Johnson's name for (oil injection) of your engine. You'll probably get some further advice and thoughts on this system.
petryshyn
Re: 40 johnson VRO
hows about Very Risky Oiling. . .(just a thought)<br />
Good Boating!
clanton
Re: 40 johnson VRO
Someone else said Very rarely oils. If you are buying, remove the starter and check the VRO pump pulse hose, starter housing rubs a hole in the hose on some engines.
Philby
Re: 40 johnson VRO
I know everybody has a downer on VRO, but as long as you check your oil is primed and take note of your warning horns it should be a good system........ shouldn't it. ?????
