Re: 40 HP Powerhead on a 50 HP Evinrude---in--->
Same block, crank, pistons & rods. Use your 50 hp intake, reeds and carbs. If the 50 head has a different number you could use it but you'll not see any difference on a normal recreational boat.
If your 50 was propped out at 5500 or less you'll probably not see any difference if you installed the 40 powerhead complete. You might see a slightly better holeshot. If your 50 was propped out at 5800 - 6000 you may see a slight decrease if you use the 40 intake & carbs.
