CpnSensible
 - Apr 29, 2002
 - 10
Hi, I have a red band 40 HP Mercury (approx mid 70's I think)<br />the motor will start and idle very roughly. When you put it into forward gear and try and accelerate the motor just dies. I have had a look at the carby & stripped it down - all ok. There doesn't seem to be any response at the butterfly when you actually throttle down - the warm up lever does have an effect though. Is there likely to be something that has become disconected or broken off?<br />The other thing I have noticed is that there is signs of moisture in the lower cyclinder (the fuel is fresh & clean) could this water be getting in from the water jacket?<br />Hope someone can help<br /><br />thanks in anticipation
