I have a 2000 30 HP Johnson jet, which is effectively a 40 HP motor (737cc). My problem is that it idles very rough and seems to smoke more than I would think it should. The idle will shake the motor considerably and will sometimes stall. When I attempt to adjust the low speed needle valve, it does not seem to respond to any changes in the settings, until I turn the needle all the way in. Other wise the motor runs fine, with plenty of compression in both cylinders. the boat sat for aq couple years before I bought it, so I am new to it and am just try to get it running reliably.
Anyone have any suggestions? I have run gas treament for water, drained the bowl and cleaned the low speed jets.
