40 hp johnson harness
nref257
Im trying to install it but I am having some difficulties, I added some pictures, as you can see, there are three plugs but one doesnt fit into anything, then on the other side, the same thing occurs, and i have these little wires with loops, any assistence will help, is there another harness i need, or am missing, maybe the harness to the battery that would have these plugs? Can i buy it on here?
nref257
Re: 40 hp johnson harness
I need the wires that connect to the battery, like the positive and negative cables, how do they attach to the harness, they may be what im missing, what is that part called???
nref257
In the group of five pictures, the first picture shows that the big plug has no male adapter to it, and in the third picture I show how the two plugs do not fit into each other.
nref257
A little research i learned that that triangle is for the trim option, and so is the male adapter on the boat, which is weird because its an older trim plug
kjdunne
Your motor is a 1998 model, new style connectors. The trim plug from the boat is the old style. They changed connectors in the 1996 model year. You need a "post 1996" cable to connect your engine to a remote control, or a "post 1996 engine to pre 1996 boat" adapter cable if you can find one. A pre 1996 cable has a big red plug at the engine end. A competent shop should be able to make one if need be.
The battery cables connect positive to the starter solenoid, negative to an engine block ground, usually a bolt or stud between the starter and solenoid. There is no plug in the battery cables.
