40 HP Identification & Compatability
Honorary Supreme Mariner
Just ;like I thought.--------That is all SCRAP, and more SCRAP !!
You funny.---It is all garbage , scrap, worthless junk.-----No need to explain at all.
Greglous
Without explanation your opinion means nothing. I am obviously using this forum to educate myself. Educationally, I chose a different path -- I am not a marine mechanic. As stated there are parts here that are obviously "scrap". However, I don't understand how you can dismiss ALL the parts as scrap. For example, what is wrong with the drive shaft? I don't need someone to tell me "SCRAP ITS ALL SCRAP JUNK SCRAP SCRAP ALL JUNK!" I need someone to explain to my WHY it's unusable. If you cannot do this, please spare me.
Greglous
Okay guys I have found a guy that might have a replacement lower unit. He has a Johnson VRO 50. I am still waiting on more details but is this a possible fit to my 1992 40 hp Johnson? What do I need to check to ensure compatability?
Greglous
No Title
Here is a terrible picture of what he has. lol
Greglous
By the way I was able to read part of the model # 40TLENJ is what I can read. I know this puts us at a 1992 not sure about other specifics.
Greglous
I can notice a subtle difference already. The water intake vents are different. On mine, they are plastic covers -- which you can remove. On his they look as if the intake is drilled holes into the casing. Is this an issue? Suggestions?
Greglous
Thanks a bunch rgs1 I did find out that the available lower was not compatible. The search continues! :cold:
