A friend of mine has a 40 hp Evinrude, probably about a 1993 model (it's a twin with twin carbs). When the boat came out of storage this spring, it hasn't been running right. At full throttle, it seems to only make 40% of it's power. The engine also revs very low for full throttle, the RPM's are probably well under 4000 RPM (just a guess, there's no Tach). The engine runs smooth and sounds normal otherwise, it's just seems like the throttle is limited. In neutral, the engine revs freely and will reach high RPM's no problem.
We checked the throttle linkage, other than there being lots of free play initially, it opens both carbs all the way. We also ran a can of carb cleaner through the carbs.
Any ideas on what we can check before we bring the boat in for service?
Thanks.
Thanks.
