No idea what year the motor is -- can't find a sticker or plate (any suggestions?). Brand new battery -- tested fine and charged up. No response when turning ignition key and no trim and tilt. There's a tiny (less than 1/2 inch long) 20 amp fuse inside of a red rubber casing inside the motor housing. Changed that and it started and ran. Left it for a few days and when I came back it won't turn over. Changed fuse again. Today it turned over, but blew the fuse immediately. What's causing that fuse to blow? I inspected the cable from the ignition to the motor and there are a couple of "rough" spots where rubber casing is a bit worn, but definitely not worn through to the wiring. I'll clean that up and put on black tape just to be sure. Appreciate any help!!
