andrey_2004
- Jun 3, 2011
- 12
I have a concern which bothers me, and I'm trying to figure out if I should be worried about this. I was checking and adjusting the timing on my 1996 Evinrude 40HP outboard, Model: E40TELEDS. The adjustment link is "pulled in" to the maximum, and minimum position screw is all the way in. During normal idle, mark is at -2 to -4 degrees, and at WOT its only at +12 degrees. From what I understand, it should be at +19 degrees during WOT. WOT position is also marked with paint on the flywheel, and written on sticker on motor. I do a lot with this motor including pulling a tube and ski, and I'm trying to get the most power out of it. The timing was measured with timing light on top cylinder. I'm concerned that its not set to spec and not adjustable any further. The moving timing part in the coil (under flywheel) is bottomed out at WOT. Did something break? Otherwise motor sometimes dies during idle, but runs well and steady. Thanks!
