Re: 40 HP 4-stroke -- carbs or fuel-injection?
You guys are just reinforcing my initial plans to buy the Suzuki. An old salt dealer whose opinion I respect and trust was the first to talk me out of the Yami and into the Suzuki, talking quick starts, timing chains vs. belts, EFI the way to go, computer diagnostics, etc. Then I read all the information on the Suzuki website about their motors and I'll just say they sold me. Then I stopped by and talked to our local outboard mechanic (small town) about EFI vs. carbed motors. He steered me towards the EFI.
So, I'm sold on the Suzuki! My very only concern is the heavy weight. This is just a jon boat. Yes, it's 18 ft long but narrow for an 18 ft boat -- just 48" bottom width. Boat only weight probably about 375 lbs. Tiller steer. 12 gal gas in the stern. Battery too. On the other hand it does have a large front deck, will have a trolling motor up front, does have a 6 ft. gun box along one side. Maybe 243 lbs. will be ok on the back. But I know 183 lbs. will be fine.
I go back and forth between the two motor options. Your input is clear and appreciated. One thing I could do would be to put my battery up front in the bow storage area. And I guess if it really helped to balance the heavier motor on the back I could even go 24 volt on the trolling motor and put two batteries up front!
Well, thanks again! You've reconvinced me which is the clear motor choice. Now if you can help me feel warm and fuzzy about having 243 lbs. back there on the back it really will be a no-brainer!
