40 hp 2 stroke yamaha neutral runs perfect in gear bogs
Jamiesonb
In neutral revs fine when I put in gear only does about 5 mph
Last 3/4 of throttle makes no Change butterflies open all the way
Fuel filter clean, vent open, new fuel connections
Any chance weak coil
99yam40
Re: 40 hp 2 stroke yamaha neutral runs perfect in gear bogs
Not likely.
Check compression on all cylinders, test spark with spark tester to make sure it has strong spark, test timing with a inductive timing light to make sure it is advancing properly.
If all of that is good then pull and clean carbs
JB
Howdy, Jamie.
Welcome to iboats. :)
Join the club of people fooled by outboards that PRETEND to run fine as long as there is no load on them, then fall flat when asked to do a little work.
Your outboard is probably running on one cylinder. Try pulling (carefully) each plug wire, in turn, while at idle. The one that doesn't kill the engine is on a dead cylinder.
Troubleshoot the dead cylinder as though it were a single cylinder engine that won't run; spark, fuel, compression, scavenging,, etc.
Good luck, and let us know what you find. :)
