40 h/p Mercury Tracker Stator Problems?
jimmywayne
I have a 40 h/p tracker that won't get fire to any of the cylinders. From what I've read that is a pretty common problem. Does anyone know what else the problem could be? I've tried to ohm it out from blue to blue/white and red to red/white . I get 1 ohm reading Does this tell anyone anything? I'm on disability so money is tight! I don't have a DVA meter any thing else I can check before I buy a stator? Thanks Jimmy
JUSTINTIME
Re: 40 h/p Mercury Tracker Stator Problems?
buy a dva and test
pull the black/yellow wire out and see if you get sparky
Laddies
Banned
A DVA is by far the best meter to use but a OHM meter will find the simpler problems so here the test specs for both meter from CDI
IMG]http://i85.photobucket.com/albums/k62/Laddies_2006/4%20CYL-ADI%20TESTS/scan0003.jpg[/IMg]
Hang on I will try again
