40 Evinrude throttle adjustment with controls
wheresthefish
the throttle from my control box seems to work fine and move smoothly. as i increase the speed from the control box the throttle increases smoothly until it hits a certain point (probably about 8 knots) then it just takes off and the throttle cant be controled smoothly. it jumps from about 8 knots to like 15 knots with no inbetween. does anyone know how to adjust this so i can maintain that smooth throttle increase with the controls. thanks.
tashasdaddy
Re: 40 Evinrude throttle adjustment with controls
possibly check the link and sinc on the motor. if that doesn't cure it, just little bumps to the throttle handle.
F_R
Link & Sync comes to mind. However, are you sure that's not the time that it breaks into a plane? It's pretty hard to try to maintain any boat's speed between the time it is squatting in the hole and the time it levels off.
