40-30 yamaha jet on 16 foot crestliner john boat
ffffg
im looking at a new 16 foot john boat with a 40 horspower 30 hp output, yamaha 4 cylinder engine for fishing and hunting the missouri river and maybe a steelhead trip to idaho, and british columbia salmon fishing... i dont want to be underpowered, but also dont want more boat than i can handle as i am older.. i need just enough for three people and day gear for fishing or duck hunting and fuel. im worried about overworking this engine or looseing fuel economy by using only the higher rpms? i wont be running it all day or even that much as i will be hunting on an island or drift fishing.. . thanks for any input.. dave (more info :im looking at buying this new boat,, a jet, and 30 is on the engine cover.. i should add that im at about 4000 ft elevation which will also reduce power... the boat is 16 foot crestliner john boat, aluminum, 270 pounds, center console , flatboat with flat bottom, and modified v in the front.. there is no chanel,it is ribbed on the bottom by forming about 1 1/4 inch square ribs going the length of the boat.. the back bottom is square.. it will haul with one to three people, not much gear for bird hunting and flyfishing... any help so i dont make a 6 year mistake on payments would be appreciated..dave
koolerb
Re: 40-30 yamaha jet on 16 foot crestliner john boat
I don't have any experience with jet drives or high altitude operation. But a propeller driven 30hp on a 16 ft Mod V would work just fine. If the jet drive delivers thrust comperable to a propeller driven outboard, it would be approximately a 25 mph boat at sea level.
John_S
From the little research I did, a while ago, setting up a jet boat is allot more involved than a prop boat. There is no changing the pitch to adjust for weight/load. Motor, boat, and load, need to be carefully matched. I remember something about a modified v in back is better than flat bottom, too. It is probably worth finding someone that does these river jet-boat set-ups, that has allot of experience. A traditional boat shop that may only sell a couple of jets a year, might not be the best at selecting the right combination for you.
JB
This is a BOAT topic, ffffg.<br /><br />Moving to Boat Forum
