4 stroke
Raybe
Just wondering how long you can leave a small 4 stroke motor on it's side? It's propper side I mean.
brodmann
You can leave it there forever. It's not going to go anywhere. You don't actually ever have to touch it again.
You can leave it there until well after the fuel goes bad
Chris1956
Some of those small motors have a fuel shut off valve. I recommend you keep is closed whenever the motor is unused.
Leaving the valve open, with the fuel tank above the carb, allows the carb to be kept full of fuel, and as the gasoline evaporates, varnish and other stuff can build up clogging it.
