I'm trying to put an impeller in a 4 stroke yamaha 100hp. The drive shaft is stuck in the crank. Have changed many impellers and know for sure all the bolts are out. The lower unit will not come off. Tried to pull the powerhead and it wouldn't budge either. Any ideas on how to get it unstuck without doing further damage? I'm sure the splines have made a lip in the crank and/or just siezed up. I've used prybars, had the powerhead supported on hoist overnight to see if it would pop loose, tried rotating the flywheel in both directions while pulling on the foot. I'd leave it alone but it overheats at high rpm and the customer has never serviced the impeller. I'm afraid I need to get serious with it now and cut the foot off so I can remove the powerhead and get some heat to the crank and shaft.
