Re: 4-Stroke outboards
G'day, Corey. What mileage you would get depends a bit on what engine/prop combo you use and a lot on what boat it is on.<br /><br />Every 4 stroke owner I have talked to claims that (s)he uses 20 to 40% as much fuel as the replaced 2 stroke (including some DFI 2 strokes!!) The engines I have tested have, unfortunately, been on different boats, but: The Yamaha 115EFI uses less fuel on a BW Dauntless 16 (1300#) than the Yamaha carbureted 100 on a Crestliner 19 (about 1200#). Not enough difference to raise cain about, but a point for EFI.<br /><br />My own boat, a Boston Whaler Montauk 17, used about 18 gallons a day running around LOTW (stop 'n' go) with a OMC cross-scavenged 1980 V4 100. This last trip it used about 6 gallons a day on the same pattern with a new Suzuki DF70 EFI 4 stroke. I actually cruised the Suzi faster, about 30, than the OMC, about 28.<br /><br />On the same trip we spent one day with a 115EFI Merc and one day with a 130 Honda. Both performed well and the Honda used more fuel than the Merc. Both used more than my Suzi, but on bigger, heavier boats.<br /><br />Bottom line? Fuel usage will be so much less than you are used to that you will triple check you tank, no matter what 4 stroke you choose.<br /><br />Red sky at night, sailor's delight.<br />Red sky at morning, sailor take warning!<br />JB
