4 Stroke Compression Question
Sea Dawg
Ready to pull the trigger on purchasing a used boat. Boat comes with a 1998 Honda 4 Stroke (not fuel injected). Compression test came back with the following; #1 = 190, #2 thru #4 = 200.
Is there reason for concern? I know 10% variance is typcially accepted but I don't want to buy a problem child. I will be taking the boat for a run on the water tomorrow any advice / info would be much appreciated.
Thank you.
pvanv
Re: 4 Stroke Compression Question
Those numbers sound fine.
