Just got my new Tohatsu 4 hp 4 stroke and will be breaking it in this month.<br /><br />My last new 4 stroke was a 1995? Yamaha 9.9; I remember the manual stating to run the first 6 gal tank with premix oil/gas, I believe 50:1 ratio.<br /><br />The Tohatsu manual says nothing about using premix for the 10 hr break in, but premix seems to have some obvious benefits. I was thinking of using 100:1 or even 200:1 oil ratio for the first gallon of gas at least - does anyone know of any reason why this should be avoided? [besides 'cause the book doesn't say so!] <br /><br />I don't think a mild ratio like that should foul the head/valves, especially at low RPM break in speed and load conditions.<br /><br />I will change the spark plug and crankcase oil after break in - some plug insulators can get contaminated if not designed for rich/premix operation, the crank oil and gear oil should be changed regardless. And of course I will run the fuel system dry so the premix does not gum up the carbs.<br /><br />Any thoughts from the experts?
