My 2000, 4 HP Johnson - J4RLSS loses power after 5 - 10 of pushing my boat. The engine seems gas starved and will only run at slow speed -- otherwise it stalls. Makes no difference if I pump the primer bulb. I rebuilt the carb last fall and it ran like a top. It was winterized by running out all the fuel and fogging the engine and storing in the basement. When I went to use the motor for the first time last this year I experienced the power lose issue.
When I fist ran the engine this year this was no stream from the "pee-hole", but a little poking and prodding with a piece of wire took care of that. Now there is a good, strong stream. Alos notice that the water temp from the pee-hole is very warm, not hot enough to burn -- may be hot tune warm.
I checked the service manual and this engine does not appear to have a thermostat.
Bought the motor last year, not sure what has been done on it other than the carb rebuild I did.
Any help/suggestions would be appreciated.
Thanks,
Dan
Thanks,
Dan
