4 hp Johnson prop help
jollyunlucky
Hello, I recently bought a 4hp Johnson Seahorse with a fiberglass prop on it that is pretty beat up, and I was woundering if I should stick with the fiberglass or get a different one. And what size would be best. Thanks.
D
DJ
Guest
Re: 4 hp Johnson prop help
Post the model year, serial and model numbers, then we can help.<br /><br />The serial and mod. numbers should be on a tag on the clamp bracket. Or, a silver dollar looking plug on the engine block.
JB
Moving to Props
